Help [Need Help]Backuping up contacts from Ally with cracked screen
Hey guys,
I recently just destroyed my screen on my LG Ally and I am backing up to an older phone. The problem is that I used backup assistant to backup my contacts on my Ally and the old droid (fully updated) does not have backup assistant. I checked my gmail account and it had 16 of my 253 contacts backed up.
In short, is there any 3rd party, pc software that I can download to rip my contacts from my broken, unreadable Ally and move them to the other Android device?
Thanks in advance.
Is the Ally still usable? When I destroyed my Ally's screen, it still worked. If it does you can just send all of them via Bluetooth.
The screen partially works, its constantly bouncing and jittering around so that would probably be extremely difficult to do. There's no software that can pull them off the of the phone? Can I yank them from the file system?
If you have then backed up in backup assist you can log on to Verizon website and get them from there. You can even export to .csv format throw that file on your card and upload the csv to any android phone. Bacon fool!
