SWEET - thank you so much!!!
So I went ahead and applied the PC36IMG.zip and it still shows the S-OFF. So I decided to start over again but now I cannot get back into Recovery - it gives me a picture of an EVO with a big red trianlge and !If it says S-OFF, repeat STEPS 5 - 7 until it says S-ON.
(NOTE: If still showing S-OFF after a few flashes, go ahead and proceed to step 9. It may show S-OFF, but it is really set to S-ON. Once you flash the PC36IMG.zip file, it should display S-ON.)
Ok so I have been messing with this for several hours and I cannot get the S-ON to appear. I followed the directions but I hit this point
Any suggestions?
Unfortunately by flashing the PC36IMG.zip you restored you phone to out of the box new without having the s-off. The good thing is, you can reflash a recovery and flash the s-on tool. You will need to go here: http://androidforums.com/evo-4g-all-things-root/259446-clockwork-amon-ra-pc36img-files.html and download the PC36IMG file for the recovery you had. Rename the one on your card so it doesnt try and flash that one or overwrite it.....add RUU to the beginning or something like that. Then follow the directions where you downloaded the recovery from to get your recovery back.
That is not working for me. When I downlaod the file from the link you send me to, I rename it to PC36IMG.zip and put it on the SD card. When I booth into hboot mode, it does not try to reload the IMG file. If I choose RECOVERY, I get the black screen with an EVO and the red triangle on it.
Any idea what I may be doing wrong?
BTW, the orginal PC36IMG.zip file is 191mb, the new PC36IMG.zip file is only 4mb - is that correct?
Ok, I see what I have done wrong. It appears that I didn't have ClockWorkMod install prior to all of this. In messing with, I must have wiped everything via hboot, tried to run the unrevoked-forever-son.zip and then applied PC36IMG.zip to the phone. Now I am stuck.
have you really ran in to that many people that do not go to folder options and un click hide known file extensions... case you guys tell every body that its starting to be funny to me...
Ok, I have done everything exactly the way you have instructed me to do and I still cannot get the EVO to read the new IMG file. Here is what the EVO says:
Checking SD
Loading.. PC36DIAG.zip
No image!
Loading.. PC36DIAG.nbh
No image!
Loading.. PC36IMG.zip
No image!
Loading.. PC36IMG.nbh
No image or wrong image!
On my SD card, I have put the following files:
PC36IMG
PC36IMG.zip
PC36IMG.nbh
Still will not work.
Ok so I put on my sd card the stock PC36IMG.zip file and I get a check list with a Do You want to start update?
@Xtremedays - WHEW... I finally got the S-On back... I had to run unrevoked again and then I could run the S-ON tool and now I think I am good to go now. I honestly could not have done this without your help. Thank you sooooo much!!!
