First question - why do you want to root the phone? Unless you have a specific reason, all you're doing is voiding the warranty for no reason. (Rooting isn't something you "just do". It doesn't change anything about how the phone works, unless you're running an app that won't run on an unrooted phone. The apps you're likely to use won't require root.)
Second, if a oneclick root written for that phone didn't work, I wouldn't fool around any further. You're more likely to brick the phone than root it.
Third, you don't root using Odin, you use adb.
