Help Need help change homescreen setting!
I was transferring a movie to my phone (in MTP mode), when my brother starts messing with my phone. He changed the setting where you can pinch to see the homescreen panels, now when I pinch the homescreens everything disappears. How can change the pinch back to seeing the homescreen panels?
Well, I can do both. If I (very quickly/fluidly) pinch OUT, I can make all the icons disappear and just show the wallpaper (enigmadroid first posted this hint in the LG Motion Helpful Tips thread). If I quickly/fluidly pinch back IN, all the icons return. Similarly, if I pinch OUT off of any normally-viewed homescreen, I get all the homescreen panels which I can choose from.
I will say that, making all the icons disappear is a lot easier to do when the homescreen isn't too crowded with icons to begin with. Hope this helps.
Thanks, but I want to disable this feature (I have no clue how my brother activated it).
Well then, I thought the feature was activated because a there was a pop up with pics of arrows (I guess it was explaining how to use the feature).
