Need help chosing a phone!
Nick021
Member
I'm Getting a new phone and I'm torn between the droid x and the incredible, or maybe the new thunderbolt. Which would you chose and why? Thanks in advance!
I would recommend a Galaxy S (it will have a different name, depending on your carrier, but they are all "Galaxy S"). The Super AMOLED screen is reason enough to get it. It does everything the best android phones do, but that Super AMOLED screen is just so awesome! If you are going to be staring at your phone's screen every day for a couple years, might as well go with the best image you can get.
id get the thunderbolt if you want 4g and such, otherwise go with the fascinate. im not a huge fan of the droid X, and the incredible is too old especially withthe thunderbolt right around teh corner.
