There's 3 searches that still show up after I cleared data on Google maps
What else can I do to fix this
Sign into your Google account on your PC and go check out your history settings. You should be able to clear from there
Did that also but from my phone under desk top would that be the same ?
I did the root explorer deal and still no diceYeah. So you cleared data and cache from google maps app and the searches still show?
What about connecting phone to the PC (you could do this in root explorer as well) and going to your (internal storage) Android folder>data>com.google.android.apps.maps and deleting that cache folder in there?
What does that do I clicked on the folder and nothing happens
I fixed mine by going to the computer logged on then went into [url=http://www.maps.Google.commmNo such luck in clearing the search history. It cleared on the PC, but not on the phone, even after a battery pull. I had no idea that Google was syncing this and some other information.
There should really be an easy way to clear your search and call history. How about a side wipe, ala recent app list.
Thx for updating us. I'm sure this info will come in handy for some!
all that clearing cache and data does not delete your search results.I finally found The Solution to clear search history from maps! When you are about to search and you see your previous search results, scroll down to the bottom and choose "Personalized with my places" from there comes new menus where you can see all your previous search and destination results. So just pick one by one and hold until you get a popup menu where you can delete from. I just did it and deleted all search resultsall that clearing cache and data does not delete your search results.
