Root Need Help Couldnt Fix it bymyself
henimex
Phone LG GT 540
* I root my phone with z4root - everything is ok.
* i uninstall some system apps ( googletalk + talk service + shazam + sims + something like wiki )
* format sd cart for link2sd and moved some personal apps (not system apps)
after restart my phone i get my first error
* UIDs on the system are inconsistent, you need to wipe your data partition or your device will be unstable
* after try to enter market "com.android.vending" force stop
i unroot my phone and make factory reset, superuser icone deleted after reset but deleted applications didnt come back... and the errors are same.
what can i do ?
my friend have the same phone can i clone it from that phone... is there a thing like copy phone memories or what can i do
Thank you for your helps
Hello and welcome henimex - thanks for joining Android Forums :)
A factory reset only clears the phone of all data, it does not return the phone to how it was before you rooted.
When you say you unrooted, what did you do? I don't think you can clone your friends phone... by clone it, you mean you want it to be back on stock firmware? You would actually need to put a stock ROM on your phone in order to return it to how it was before.
yes i need to return to stock firmware, how can i do that. is there a tutorial for it im using my phone in Turkey
Firmware 2.1-update1
Kernel vers. 2.6.29
For info, I've just had a quick look and found something that should (hopefully) help you out.
Head here and you should be able to download the correct firmware for your phone (all listed alphabetically by country)... at the bottom of the list, there are instructions on what you need to do.
Let me know if you are able to get your phone sorted and I can link it in the root sticky :)
You have said that you are now unrooted... could you let us know what you did to unroot?
i send z4roo.apk via bluetooth and install it again... and i saw a link there as "unroot" and clciked phone restarted and superuser icon was deleted after restart. and in program root selection is active again...
As I have no experience with your phone, I am not 100% sure what to suggest on the stock side of things.
You could re-root your phone and put a custom ROM on there... at least that way, you would have a working phone again! :)
now everything is a mess... i try to write rom but when kdz update is working screen freeze and now only lg logo on black screen... nothing more. tried lots of things but still same
I am not sure what to suggest... as I said, I have no experience with your phone. I will see if any other staff members can suggest anything for you.
bro cant u send it a little bit earlier... :) i found another topic just like the same one u send to thread after i solve the problem ty to everyone...
now i need a good backup revocery program... becouse i will do another root things etc and if i fail i want to restore...
