Root Need help deodexing systemui.apk
Qpid1977
I've been able to use baksmali to deodex some of the files from /system and /framework, but when I try to deodex systemui.odex, I get the following bootclass path error:
Error occured while loading boot class path files. Aborting.
org.jf.dexlib.Code.Analysis.ClassPath$ClassNotFoundException: Could not find sup
erclass Landroid/backup/IRestoreSession$Stub;
at org.jf.dexlib.Code.Analysis.ClassPath$ClassDef.loadSuperclass(ClassPa
th.java:788)
at org.jf.dexlib.Code.Analysis.ClassPath$ClassDef.<init>(ClassPath.java:
676)
at org.jf.dexlib.Code.Analysis.ClassPath.loadClassDef(ClassPath.java:280
at org.jf.dexlib.Code.Analysis.ClassPath.initClassPath(ClassPath.java:16
3)
at org.jf.dexlib.Code.Analysis.ClassPath.InitializeClassPathFromOdex(Cla
ssPath.java:110)
at org.jf.baksmali.baksmali.disassembleDexFile(baksmali.java:104)
at org.jf.baksmali.main.main(main.java:282)
Error while loading class Lcom/android/server/BackupManagerService$RestoreSessio
n; from file .\services.zip
Error while loading ClassPath class Lcom/android/server/BackupManagerService$Res
toreSession;
With most of the deodexing, the bootclass path error is referencing an obvious .jar or .odex, but this one has me baffled. I've tried using any .jar or .odex I can find that remotely references backup, but no luck.
Any ideas?
So, I feel like I'm seeing a trend emerging. This phone is a decent buy, prepaid spec.-wise, but is a huge pain in the ass to develop on. I was very eager to upgrade to the Optimus Elite after I saw the great things Jerry was able to do with the V. I looked at the specs and thought it was a no-brainer. You have appeared to win this one LG/Virgin....
Once there is a working recovery, things will start to happen. Unfortunately when it takes this long to get started, excitement will have waned.
