I just ordered my Nook color and trying to get everything set up for when it arrives. I gone through the tutorials and I'm pretty straight on how to install it, but I still am having a little trouble figuring out which build to go with. I've read in several places that CM7 nightly 150 and 160 are very good and stable builds. I checked the website and 150 is not listed anymore and when I try to download 160 it says there is no file there. Should I just go with the most current nightly when I receive my Nook or is there a way to get either 150/160. Also, with those, which version kernel should I get for that. I do want the newer one for the faster booting and battery life but I want to be sure I am getting the right one for those versions.....also where to download said kernel.
Thanks for helping the newbie out!
Thanks!
