emoshurchak
Member
I am using Juice Defender to help extend battery life. The graph lines on Juice Plotter were thin and gradual and it worked well until a couple of weeks ago. Now for some reason, the graph lines take steep nose dives and are thick and green or yellow. I have not downloaded any new apps recently and haven't changed the way the phone is used (Vibrant i9000). This battery drain often occurs when I am sleeping. For example, last night the phone was fully charged when I went to bed. Here are a few of the readings during the night:
11:00PM Dec ll 100% 28.0C radio:APN
2:00AM Dec 12 61% 30.0C radio:APN
5:30AM Dec 12 15% 29.0C radio: APN
Battery history since last unplugged:
Running (100.0%)
Screen on (6.6%)
The display is off for the evening. I have tried disabling Juice Defender and turning off alarm but no difference. I get the same battery drain during the day with only light use of the phone. I am at a loss to diagnose the problem and would appreciate any ideas.
Running (100.0%)
Screen on (6.6%)
