Accessories Need help finding a case and battery!!
bigceej
I recently got a cheap hard rubber case from Ebay and well you get what you paid for. I would like a thin case that covers top and bottom. If there is any that are cheap but high quality that would be perfect!!
What are some cases that you would recommend, thin profile or not I just need someones opinions on some good cases.
Also I am looking to find a battery that will fit in the stock battery door... are there any?
also what is a good cheap extended batter like 3500mh? are there any cases for this size battery?
Thanks for your helped I have searched around and read tons of posts but I can't seem to find what I am looking for... If you can help it is much appreciated!!
