EricS96521
I was running Virtuous 2.6 and I decided to run some tests with task killers/force closing apps, etc and wanted to get back to the stock 2.1. I downgraded to 2.1 just fine, installed the May OTA update, and went to install 2.2 with the PB31IMG.zip file. Instead of the bootloader giving me the option to update, it simply says 'parsing' for about 2 seconds and then goes back to the HBoot menu.
Now when I reboot the phone, it will only boot into recovery and nothing else. I put the 2.1 downgrade back on to the sdcard and tried updating again and it just says 'parsing' and doesn't work.
Please help me. My phone is completely useless now.
