I do a lot of graphics artwork and would be willing to help in the logo design. Post copies of your logos with transparent backgrounds and I'll return with some nice logos. If the ones I return aren't to your liking, I can design most anything. Let me know![]()
Here is some of my artwork, and here are some of my apps.Can you provide a link to your portfolio?
Thank youJust wanted to say that's some very nice work you got there, ardchoille![]()
The top one (green and blue) is what I was going to do with your other icons. You gave that green and blue one a glossy, three dimensional look.. it's beautifulI have also this one :
What do you think?
I totally agree, that would look very nice.In the OP like 2, 3, and 5. Would say I like 2 the best.
Would like to see if you could put the "ir" inside the green android screen, then you could use the android tv with "ir" insdide as the icon.
Number 4 at the top, or the green one from these.I have also this one :
What do you think?
Whoa. Just Googled this project. Sounds like something I'd be interested in. The Xfinity TV app only goes so far with regards to doing away with my remote- can't switch inputs with it.
How's the progress on the project, and what physical hardware would be required?
. The module's cost for beta testers will be very low. If you are interested about the project updates you can follow me on twitter @irdroid
