So i want to root my phone samsung galaxy S4 running on lollipop 5.0.1 but i dont have a computer to use root method with and towelroot didnt work so if someone can help it would really great thx
Fortunatly i found but it works only with kingroot bu hère it is:1:first got to kinguser
2:go to settings with the icon in the top right of the main screen and go to root authorization setting
3:got to remove root authorization and select yes
There! After that no need to do anything else cause the app exit himself. If you want to root again run king root and he will do it automatically
