ok so i had the 2.1 leak on my phone, just recently i read the thread universal rooting on eris for dummies i did that now i wanna install a new rom on my phone how can i do that?
I would advise against ROM manager. ROM manager has been problematic for some on the Eris. The best way to switch ROMs is to download the ROM of your choice and place it in the root of your sdcard. Once it's on your sdcard follow the instructions from the post below.
Download a ROM of your choice, and then put it in your android-sdk/tools section. After all that is done, (btw, you should have the android-sdk on the root of your C: drive). You must plug your phone into your computer, don't mount the SD card, keep it charging and enable USB debugging (in applications>development)
It should take awhile because roms are huge files, just wait for it to go.
Then power off your phone, reboot back into recovery (End button and Vol. UP). Then click flash zip from sdcard, select your ROM and wait for it to install everything, reboot and your set.
