need help getting adb on pc
after typing adb devices it says adb is not recognized as an internal or external command
ok i hit the screenshot button now how do i find the screen shot
prt sc button?
So if you use the print screen button then you have to paste the image into another program like mspaint. Then save it.
But I can already tell you from the error that you posted, you aren't running the command from the right directory.
To make it easy, right click on your platform-tools folder (or whatever folder your adb utility is in) and select "open command window here". I think you can do this in windows 7.
cmd prompt
  • 3837-3238:Untitled.png
Did you try what I said about right clicking the folder and choosing open command prompt here?
Your command prompt needs to start with the location of the folder that adb is in. For example, my adb is on my desktop in a folder called platform-tools. So when I use adb, my command prompt looks like this:
c:\desktop\platform-tools> adb devices
To make this as easy as possible can you please do the following?
Copy the zip file that you have called platform-tools_r30.0.0-windows and paste it on your desktop.
Rename the file to platform-tools
Right click on it and extract it.
Now you should have a folder called platform-tools with a bunch of files inside.
Once you are there let me know and I'll tell you what to type exactly
Okay great! It looks good. Now open command prompt and type these things and press return/enter after each
cd desktop
cd platform-tools
Now your command prompt should look like
Now use the adb devices command
Yes it looks good. It says unauthorized. I think you need to make sure your phone is unlocked and run the command. Then give it permission on the phone when the message pops up. But yes it's finally working
Now that you're up and running I'm going to go for the night. If you have any other questions I bet @ocnbrze can help you if they are around for awhile.
