Apps NEED help in debugging!!
  • Thread starter Thread starter sethvaibhav95
  • Start date Start date
S
sethvaibhav95
Guest
Hey guys need help in debugging,dunno what's the error.It just stop working and crashes when i click login.After pressing login button it shows attempting logging and crashes.
APP description- Basic app for login and displaying HELLO
Server in use-Wamp Server
below is the logcat, loginactivity, login.php and jasonparser.java code for my app.
ANY help would be appreciable.
LOGCAT
10-05 10:38:23.310 28315-28328/com.sam.kiet E/AndroidRuntime﹕ FATAL EXCEPTION: AsyncTask #1
Process: com.sam.kiet, PID: 28315
java.lang.RuntimeException: An error occured while executing doInBackground()
at android.os.AsyncTask$3.done(AsyncTask.java:300)
at java.util.concurrent.FutureTask.finishCompletion(FutureTask.java:355)
at java.util.concurrent.FutureTask.setException(FutureTask.java:222)
at java.util.concurrent.FutureTask.run(FutureTask.java:242)
at android.os.AsyncTask$SerialExecutor$1.run(AsyncTask.java:231)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1112)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:587)
at java.lang.Thread.run(Thread.java:841)
Caused by: java.lang.NullPointerException
at com.sam.kiet.LoginActivity$AttemptLogin.doInBackground(LoginActivity.java:87)
at com.sam.kiet.LoginActivity$AttemptLogin.doInBackground(LoginActivity.java:60)
at android.os.AsyncTask$2.call(AsyncTask.java:288)
at java.util.concurrent.FutureTask.run(FutureTask.java:237)
LOGINACTIVITY.JAVA
package com.sam.kiet;
import android.app.Activity;
import android.app.ProgressDialog;
import android.content.Intent;
import android.os.AsyncTask;
import android.os.Bundle;
import android.view.View;
import android.widget.Button;
import android.widget.EditText;
import android.widget.Toast;
import android.util.Log;
import org.apache.http.NameValuePair;
import org.apache.http.message.BasicNameValuePair;
import org.json.JSONException;
import org.json.JSONObject;
import java.util.ArrayList;
import java.util.List;
* Created by Vaibhav on 10/2/2015.
public class LoginActivity extends Activity implements View.OnClickListener {
private EditText user, pass;
private Button bLogin;
private ProgressDialog pDialog;
JSONParser jsonParser = new JSONParser();
private static final String LOGIN_URL = "http://localhost/login.php";
private static final String TAG_SUCCESS = "success";
private static final String TAG_MESSAGE = "message";
@override
setContentView(R.layout.login);
user = (EditText) findViewById(R.id.username);
pass = (EditText) findViewById(R.id.password);
bLogin = (Button) findViewById(R.id.Blogin);
bLogin.setOnClickListener(this);
@override
public void onClick(View v) {
switch (v.getId()) {
case R.id.Blogin:
new AttemptLogin().execute();
default:
break;
class AttemptLogin extends AsyncTask<String, String, String> {
boolean failure = false;
private String username,password;
@override
protected void onPreExecute() {
super.onPreExecute();
pDialog = new ProgressDialog(LoginActivity.this);
pDialog.setMessage("Attempting for login...");
pDialog.setIndeterminate(false);
pDialog.setCancelable(true);
pDialog.show();
username = user.getText().toString();
password = pass.getText().toString();
@override
protected String doInBackground(String... args) {
int success;
try {
List<NameValuePair> params = new ArrayList<NameValuePair>();
params.add(new BasicNameValuePair("username", username));
params.add(new BasicNameValuePair("password", password));
Log.d("request!", "starting");
JSONObject json = jsonParser.makeHttpRequest(LOGIN_URL, "POST", params);
Log.d("Login attempt", json.toString());
success = json.getInt(TAG_SUCCESS);
if (success == 1) {
Log.d("Successfully Login!", json.toString());
Intent main_activity = new Intent(LoginActivity.this, MainActivity.class);
finish();
startActivity(main_activity);
return json.getString(TAG_MESSAGE);
} else {
} catch (JSONException e) {
e.printStackTrace();
return null;
@override
protected void onPostExecute(String message) {
super.onPostExecute(message);
pDialog.dismiss();
if (message != null){
Toast.makeText(LoginActivity.this, message, Toast.LENGTH_LONG).show();
LOGIN.PHP
<?php
if($_SERVER['REQUEST_METHOD']=='POST'){
$username = $_POST['username'];
$password = $_POST['password'];
require_once('dbConnect.php');
$sql = "select * from users where username='$username' and password='$password'";
$check = mysqli_fetch_array(mysqli_query($con,$sql));
if(isset($check)){
echo "success";
}else{
echo "Invalid Username or Password";
}else{
echo "error try again";
JASONParser.JAVA
import org.apache.http.HttpEntity;
import org.apache.http.HttpResponse;
import org.apache.http.client.ClientProtocolException;
import org.apache.http.client.entity.UrlEncodedFormEntity;
import org.apache.http.client.methods.HttpGet;
import org.apache.http.client.methods.HttpPost;
import org.apache.http.client.utils.URLEncodedUtils;
import org.apache.http.impl.client.DefaultHttpClient;
import java.io.BufferedReader;
import java.io.IOException;
import java.io.InputStream;
import java.io.InputStreamReader;
import java.io.UnsupportedEncodingException;
public class JSONParser {
static InputStream is = null;
static JSONObject jsonObj ;
static String json = "";
public JSONParser() {
public JSONObject getJSONFromUrl(final String url){
try {
DefaultHttpClient httpClient = new DefaultHttpClient();
HttpPost httpPost = new HttpPost(url);
HttpResponse httpResponse = httpClient.execute(httpPost);
HttpEntity httpEntity = httpResponse.getEntity();
is = httpEntity.getContent();
} catch (UnsupportedEncodingException e) {
} catch (ClientProtocolException e) {
} catch (IOException e) {
try{
BufferedReader reader = new BufferedReader(new InputStreamReader(is, "iso-8859-1"), 8);
StringBuilder str = new StringBuilder();
String strLine = null;
while ((strLine = reader.readLine()) != null) {
str.append(strLine + "\n");
is.close();
json = str.toString();
} catch (Exception e) {
Log.e("Error", " something wrong with converting result " + e.toString());
try {
jsonObj = new JSONObject(json);
Log.e("json Parsering", "" + e.toString());
return jsonObj;
public JSONObject makeHttpRequest(String url, String method,List<NameValuePair> params) {
try {
if(method == "POST"){
httpPost.setEntity(new UrlEncodedFormEntity(params));
}else if(method == "GET"){
String paramString = URLEncodedUtils.format(params, "utf-8");
url += "?" + paramString;
HttpGet httpGet = new HttpGet(url);
HttpResponse httpResponse = httpClient.execute(httpGet);
try {
is.close();
try {
return jsonObj;
A null pointer exception is thrown in your function onPreExecute as indicated by the stack trace, line 60:
Line 60:
Most likely, user and pass are null because you are calling findViewById too soon. Wait until onFinishInflate() before calling findViewById:
