Root need help installing a rom
OK i just rooted my phone and was wanting to install Virtuous rom 3.0.1.
I made a backup with titanium (free) and dowloaded rom manager. When i download Virtuous
3.0.1 from rom manager what do I do next. I thought rom manager would automatically install it from here. Do I need to choose something from the sd card? Please help thanks
First off I would do a backup nandroid or go into clockwork recovery and do a backup. Rom manager will also prompt you to do a backup so you could do it that way as well. Then reboot and go back to rom manager dnld your ROM and then it will prompt you to do a "wipe data and cache" and a "backup"
Choose both if you did not manually do a backup and go from there.
All this info is right here read it well it will help you immensely.
