Root Need help installing Cyanogenmod
fkacct
I installed G.O.T. 2.2.1 and rooted....now I want to try Cyanogenmod, but have no idea how to install it. Any help/links will be appreciated!
Second question: What is OpenRecovery? Why is it used for?
Nevermind, I figured it out. For those of you that need help with this:
1. Flash Milestone with Vulnerable recovery SBF
2. Load Open Recovery: You can use the original open recovery or the ones modified by G.O.T. or Androidiani (the two ladder ones have more functionality). To load open recovery, copy the "Open Recovery" folder and "update.zip" included in all three versions into your SD Card. Hold the "x" key while powering on your phone. When the Triangle/Exclamation signs appears, press the up volume and camera keys.
3. Apply CM file and Google apps file as updates.
