Root Need Help Installing MIUI on the EVO
zeux6
Member
Thank God for nandroid. I have been trying to install MIUI but everytime I do, I get the error 7 message. Is there something I am not doing right? Could anyone here post how you installed this great looking ROM in step to step instructions? I am currently on the latest Fresh and using the latest Fresh kernel. Thanks a bunch.
I don't know exactly what recovery you are using but when going to a CM or MIUI based ROM it seems to be better off if you have the alternate RA recovery installed......You can back up your WiMax keys too which is important...If I were you I would install Rom Manager from the market and flash the alternate Recovery from ROM Manager. Then see if you MIUI Rom installs...also try re-downloading the ROM and installing on you SD card cause it could just be a bad download.
