Need some help, I have read through and have not found any solutions, if its out there I applogize!
So here is the scoop, I have a Verizon HTC incredible 2 (love it!) and I unlocked it to use on my att account.. Worked great making calls and texting from home.... left my house today and found out that I have no data access outside of my home wifi
So stuck the sim back into my iphone and ran my errands blabla, when I had a chance to do some research I found the AP settings to manually enter, so when I put the Sim card back into the droid It does not see the att network anymore.. I have made sure I switched to GSM mode I check and it says sim is unlocked... I even tried a heard rest and start all over.. I t just gets no signal
While searching for a setting to fix, I got an error... If I go to the gsm settings, when I try to open that I get the error : Network or sim card error If i put the sim card back into the iphone it works great! I am stumped! It worked a couple hours ago! Uggg
Anyone had this issue?
Thanks
Thanks
