Root Need Help No network connection !!
Jaay Dogg
Android Expert
So i was testing some roms & now my 3g is broken NO NETWORK, I tried the broken radio fix by apache thunder but it didn't work, Dammit, Anybody delt with this problem ? If i can't fix it i guess it's a good thing It's insured, When i dial ##3282# user name is blank & is my mms url ? Any help with this would be great. & it force closes on my cdma options
Testing roms will not break data or mms. Mms url will show as blank, how ever it is there. As in if you flashed my rom or was stock. Mms would be there, as for the username being blank may be the problem.
What did you actually end up doing that broke data in the first place? As in I know it wasn't from flashing my rom because you are probably 1 out of not sure how many with the issue.
tried to do the mms fix ##3282# & did what josh worth posted, he said go into EPST edit mode & entered http://mmsc1.uscc.net/mmsc/MMS that didn't seem to help so the other one is http://mms.sprintpcs.com & he said to erase the RTSP/HTTP settings to where there blank, I wrote the info down just in case but it's not fixing it. You know how to fix this 2fast ?
1. download and open MSL reader from playstore
2. open phone dailer
3. dial ##3282#
4. click on Edit Mode and enter code from msl reader
5. Click on advanced
6.Click on MMS server URL
7. Enter your provider's mms URL
Sprint = http://mms.sprintpcs.com
Cellular = http://mmsc1.uscc.net/mmsc/MMS
8.get your msl (msl reader - play market), then dial ##3282# Go to edit enter the msl then advanced Rtsp/http setting Delete everything out of the two ip spots, it should show nothing. For the ports change to 0 Then back button, menu, commit modifications
What were you doing messing with the mms settings for? If you were testing my rom, they were preset. How ever you messed up your activation settings by the sounds of it. Where I don't know the boost ones, either try the activation menu or you will have to call boost. Where if you do the later tell them you got no service at all, that your activation was lost.
3. dial ##3282#
I only copied and pasted a fix and sourced it as well
Sourced what? What he posted was to fix mms no working and the youtube fix I figured out. Neither will gain 3g back though.
He's saying he used some mms thing I posted well if I posted it it came from somewhere else and by sourcing it I mean I cited whom it came from or where. So it wasn't from me is what I'm saying.
