need help on 2 question
S
stanleyy
Guest
question 1
i keep seeing this memory card icon on the top of the screen flashing, it flashing for a few second and it gone and it comes back and start again
i know i have insert the memory card correctly into the phone because i can access the file save on it
what seems to be the problem ?
question 2
dont know if my problem is the same as below
http://androidforums.com/sony-ericsson-xperia-x10/208940-cant-download-any-apps.html
http://androidforums.com/sony-erics...d-market-download-unsuccessful-error-fix.html
http://androidforums.com/sony-ericsson-xperia-x10/208353-help-android-market.html
http://androidforums.com/sony-ericsson-xperia-x10/207938-market-not-working-once-again.html
http://androidforums.com/sony-ericsson-xperia-x10/204387-market-issue.html
i can download from the market but with some app it dosent download at all,it automatic pause the download and stays there
i try these fix
i think it call factory reset or something
reinstall the update (from 1.6 to 2.1)
went to application and clear the cache from "market" and "download manager"
but i still cant download(just some app not all of them)
what seems to be the problem?
i didnt have these 2 problem when i was using 1.6 but since i upgraded to 2.1 i have these 2 problem
anyone out there has the same problem and has fix it
i need your help
thanks
Will just have to sit it out then. When the Market works it works, if it doesn't and none of the solutions work there isn't much you can do.
