Root Need help on my admire
jj123456
I tried downloading a custom rom on my android and deleted the stock rom in the process the custom rom didnt run so my phone only turns on to the samsung screen and freezes how do i flash the stock rom to my phone need step by step instructions not very good with phones and what to download to flash it on my phone
Hi, welcome to android forums. Check out the all things root section. It has everything you need to root and rom yer admire.
just boot into CWM and mount your phone to the computer through there. find a rom, download it, transfer it to your sd card and then disconnnect from the computer. then just flash the rom but make sure to wipe everything right aka factory reset and wipe system, just wipe everything but the sd card, that would be stupid
