Root Need help please
novarider
I decided to do a factory wipe and nand restore on my phone because the internal memory was low. The wipe went fine but when I try to do a nand restore I get this message.
Error : run 'nandroid-mobile.sh restore' via adb
What cause this? Is my recovery messed up?
Can you someone me fix this? Any help is appreciated!
Did you wipe cache and dalvik cache as well? If you did, then try rebooting and going to recovery once more. I have had this issue come up before and usually a reboot resolves it.
make sure ur battery level is above 40% and preferably have ur phone connected to the charger when doing the nandroid. i had the same problem once
I just finished reading about this solution and it definitely makes sense. Although, I don't think the phone charges while in recovery so if you are really low on battery, charge it while it is off.
