Need help please..
Okay so i bought a Galaxy S2 from Boost Mobile (Epic 4G touch) and i tried to get CM 10 on it...turn out it was a bad move. I used Odin on my computer and now My Phone is on the Sprint Network.... I really need to get it back to boost anybody know how to? Anybody has the Boost mobile PDA file?
Just 'cause the ROM says 'Sprint' it does not mean you are on Sprint.
Check your baseband (settings > about phone > baseband) and see if it is FH29 or FH31, if so you're on Boost.
Boost runs on the Sprint network. You can still make calls right? coincidently does sending MMS work?
anyways there is a guide that tells you how to go back to stock Boost. its super easy. if you can handle installing CM10, you can handle that.
good luck breh
This will help you take your phone back to stock. You will have to root again after.
http://androidforums.com/galaxy-s2-...-root/621393-tutorial-return-boost-stock.html
Codegerm :)
