Help Need help plz - Deleted contacts
Darkd10
Im a dumbass. Here is the rundown:
I use Cricket's Mybackup service for my contact backup. The problem is that when I flashed my ROM to CM7... I lost all my contacts along with it.
I did make a backup of the original rom using the CWM. So I am assuming the program will still be in the backup.
Are my contacts able to be recovered?
Do I have to stock then reflash to get my contacts back or is there some other way of acquiring this program?
Help is greatly appreciated. Thx
For future reference, go to:
CONTACTS > MENU > MORE > MANAGE CONTACTS > BACKUP TO SD CARD.
After you do that, connect to your computer, find that backup, and copy it to your computer. That way, if you ever do anything and lose your contacts, you will still have a backup.
You can always put the file back on your card and restore them from there.
CONTACTS > MENU > MORE > MANAGE CONTACTS > RESORE FROM SD CARD.
to get them back....
Thank you both greatly. I realized after I flashed that I should have backed them up to my SD card. Thx again
Another way you could have done it would be to send your contacts to Google.
Go into contacts, then hit menu and tap on more. From there go to manage contacts and select copy contacts. Then pick the ones you want to copy and copy them too Google.
Yeah I tried to use google to backup, but for some strange reason it didn't work. Either way I fixed it..
Thankfully lol
