Help need help plz
earlly
i have note 10.1.....
i use home internet ,,,but when i go to work and use work network,,,it stuck on ip address of home network...
how to reset the ip address....plz help
Does that cause any network access issues? If not, why does it matter? If it does, how does it affect access to Internet when you are at work? We need mor einfo.
it does effect...i connect to internet at work...but the access point stuck wth that ip in the pic
i modify the network config and change proxy setting and dhcp...but nothing work
(f.y.i) we use proxy setting in our wireless network at work...that is why i change proxy and dhcp.....
is there a way to reset the wireless setting
i ope i got u the info u need....thnx
