Root Need help quick
D
Deleted User
Guest
Ok so I put Velocity 1.0 on my sd card. I reboot into recovery. I made a Nandroid backup. Wiped Data, and both caches and when I went to install Velocity 1.0 the zip wasnt there. but when i checked before it was there.
WHAT DO I DO?
Restore your nandroid that u should have made. And mount the sd card, I know when I installed this rom it installed amonra recovery for me.
When I click restore nand it show something that says: mem=223M Should I click that and what do you mean by mount the sd card. Should I just reboot into recovery and try it again
Yes your nandroid should be in mem 223, when I say mount your sd card I mean, restore your nandroid, download astro from market, and try to find the zip with astro, if you can't find the zip then. Try to download again. If I knew how, I would send you a zip. And lastly, did you use your ally to download the zip, or a comp?
I checked with astro that i had it before i flashed and stuff and i got it from my computer
try putting it on your sd card again, the file size should be 108mb. If its not, then download the rom again. Or flash your backup and dowlnoad with your ally. That's how I flash roms, never failed once
Ok here is the wierd thing though I had two other zip files on my sd card and they didnt show up either
Amonra will only show a certain number of files.
Make a folder on your sd card, label it roms or something and put it in there. Folders show up first.
You probably just have too many files.
Ok thanks.
Ok this might take a while. Cause if you remeber my first thread which was reboot into recovery blue screen. Im havin to keep pulling my battery and reflashing cause of blue screen
got it to work
THANK YOU: codala1810 & crash89 thanks again this is the second time you saved me
When I started to overclock my ally to around 800 it just started to restart itself and restarting and restarting what should I do
tigersfan1
you did not use the guide to root froyo did you? If I remember correctly, you used the easy method? Correct me if I am wrong.
I think that is the reason you have to keep flashing your recovery. There is a file that when you reboot, it reinstalls the stock recovery.
The guide addresses this issue, and removes that file.
tigersfan1
Ok so does this mean my phone is screwed or what?
Turn the frequency down, some phones can't handle the higher frequency,I keep mine at 787
Ok thanks I wasn't gettin enough time to get to it before it restarted. But I was able to get to it and slow it down
No, just means you should use the guide. It tells you how to remove that file from the system so you dont have that problem.
There is a reason that the GUIDE is the recommended method to root froyo, and why the devs are not offering support to the other method.
Is it possible for me to just take out that file or do I have to follow the whole guide
Best bet is to follow the whole guide and do it right so you have fastboot, unless your phone shipped with ZV6.
You need adb set up on your computer. Read the guide.
So I have read the whole guide before and I feel like I could easily mess my phone up. So what is the file that I would need to take out and what does it do
