Help NEED HELP : RECOVERY SEANDROID ENFORCING
Cylaux
My Samsung Galaxy Note 3 SN-9008W was perfect yesterday.
Running 4.4.2 KitKat
Rooted the Phone with Towelroot
Install Clockword Recovery
Flash was Succesful
Installed Bobcat KitKat ROM and Gapps using ROM Manager
Restarted Device
Now only showing :
"Samsung Galaxy Note 3"
And in the upper left corner it says :
"RECOVERY BOOTING"
"RECOVERY IS NOT SEANDROID ENFORCING"
Keeps booting like that "Bootloop"
Tried all buttons (Home, Power, Volume at once)
Download Mode won't appear
Device doesn't even connect to Computer, however it does charge
Any solution to this?
Try taking your battery out and back in to get to recovery with the volume up + home + power button way. Battery out then press and hold all three and battery back in at the same time. If you can get to recovery clear cache and dalvik cache and reboot.
So press all of the 3 buttons first, than put the battery in?
I took out my battery several times, and pressed all 3 buttons several times as well prior to the making of this thread
I fear that this Bootloop might be Permanent
You can try a USB jig, it's worth it for the tiny amount they cost. I've not tried using mine on the Note 3's USB 3 port. I will when I get home and let you know if it works.
Yes, a USB jig might just get you out of trouble.
Tried mine just now. Turned the phone off completely then plugged in the USB jig forced my Note 3 straight into download mode. I did not need to power it on, it went straight to download mode.
If you can get to download mode flash your stock firmware and you should be good to go.
If a jig won't work, then you have indeed hard bricked it, and you'd need a Jtag repair, which might or might not be successful in itself.
