Root Need Help Regarding On How to Root Droid X2
Paste is for the checksum provided on the download page, for the file
browse for the filename you are checking
could you maybe PLEASE provide with a link for the CM10 file because it seems like everyone I find is wrong or the page won't pull up. I think the Gapps file I have is right because it actually shows it's a zip file but the other has a Question mark and is only like ALL text and not the actual install components needed.
I think the CM10 file on my computer is right but I can't seem to get it to a regular file. What I mean is the Gapps file has the zip icon next to it but the CM10 file has like a box with a cd in front of it symbol. So how can I get it out of that state and to the regular zip file with the icon next to it? When I press open it pulls up this box that says it's downloading but I can't find it after that.
does the md5 checksum match?
Yup! That one seems to be alright.It actually has all the install components. Now I can just watch the video and do it. One last question. In the video he says to make sure you can locate the 2 files, and he puts them under one folder. How would I do that? Or isn't it really necessary?
just remember where you put them.
Ok and one last thing. It says on my droid that I have one new update for Superuser from the Play Store. When I go to the Play Store the app is Superuser by ChainsDD and it has the top part of the android man as the image. Should I update it?
no reason to, but is OK either way
Hey MIB, what's the point of the concise guide to getting CWM working with A3?
And it seems I have a battery issue. I looked it up and seen that other people have had this issue with A3. Any advice ?
Main uses for CWM/BSR is nandroid backups and flash roms, also good for factory reseting a rom.
A is for Alpha, means it experimental. Development was abandoned and I haven't really used A3. CM7 and Eclipse are much more stable, but only Gingerbread (android 2.3)
