Root Need help removing boot up screen
I am using most current build of cm7 reloaded. I had previously tested Minimal Triumph before switching over. When I boot up the phone the minimal triumph screen appears. After a few seconds the cm7 boot animation follows and everything is cool. How do I remove the minimal triumph screen?
you flash another splash image. :D if you go to my thread im sure you find one you like. and if not the stock motorola logo is at the top also
