Ok I decided to finally root and followed every single step necessary. Did all the steps, including the pre root. Everything was going good. Was running Unrevoked and following all the steps as they appeared. On the Unrevoked screen on my cpu, it said it was Done. But on the phone, I got this:
Clockwork Recovery v.2.5.0.1
- reboot system now
-apply sdcard:update.zip
-wipe data factory reset
-wipe cache partition
-nandroid
-partitions menu
-advanced
SD card mounted
Installing Data:local/unrevoked-forever.zip
Installing update
unRevoked forever S-Off patch v1.1
Verifying system type...
E:unsupported radio version
E: update failed. Check sdcard/soff.log
E: error in data/local.unrevoked-forever.zip (status 42)
Installation aborted
/tmp/recovery.log was copied to sdcard/clockwork/recovery.log. Please open ROM Manager to report the issue.
And there's a triangle with a yellow exclamation point in the middle of the screen. I am brand new to this and have no idea what's going on.
Thanks to anyone who can guide me through this!!!
- reboot system now
-nandroid
-partitions menu
-advanced
SD card mounted
Installing update
