i cant find the drivers to install so i can root any help the problem occurs when i go to install using the unrevoked walkthrough that comes with the download
To get the needed USB drivers for windows, first install HBOOT by following these directions.
Once that is done, you should install HTC Sync from here. It is called "HTC SYNC UPDATE FOR WINDOWS". You will need your phone's serial number (which can be found under the battery, or in the settings menu of the phone) in order to download the application. Once HTC Sync is installed, uninstall it immediately from your computer.
Once these two items are done, the unrevoked 3 application should work correctly.
Edit: if you have any more questions, the directions located here might help.
