Root need help rooting
julie524
I'm finally rooting my Captivate and I'm not sure what I'm doing wrong. I'm currently running 2.3.5 Gingerbread.
I'm sure that I have the zip file in the right spot as I emailed myself the file and downloaded it from my phone. When I reboot the phone while holding down the volume buttons the screen will read as...
Android system recovery <3e>
Samsung Recovery Utils
- for BML -
Enter: POWER Key, Select : Vol UP / Vol Down
reboot system now
apply update from sdcard
wipe data/factory reset
wipe cache partition
--Copying media files...
Successfully copies meida files.
# MANUAL MODE #
--Appling Multi-CSC...
Installing Multi-CSC
Applied the CSC-code 'ATT'
Successfully applied mutli-CSC.
There is no option to "reinstall new packages" or "install recovery packages" or anything similar.
Help and thank you!
