Help Need help setting up an account to download apps
Android 2.2 netbook
WIFI
I set up an account using my yahoo email with my app market on my netbook. The market doesn't locate the app I want to install. When I try to get it manually I get "there is no phone connected with this account."
I used the same email address to create an android account at google. I checked the "Accounts and Sync settings" and there was no account listed, so I tried to add one.
After putting in my yahoo email address and password I clicked "Next"
That brought me to another screen where it had split my email adress. The first part is under "Domain\Username" the yahoo.com part is under "Server". Both SSL options are checked.
When I click next I get "Setup could not finish. Unable to open connection to server."
I need to know the information to put into this screen to connect to the server please?
To create an account in "Accounts and Sync settings" you should use the email address/password of your Google account and not Yahoo's
Harry
Ok so I got my yahoo google apps account turned into a gmail account.
I then tried to add an account and had the same problem. The only difference is that now the server says "gmail.com". But I get the same error message.
