Can someone help me step by step, to connect my samsung galaxy i9000 mobile to MTNLTriband(Plan 599 Unlimited) wifi. Router DNA-A212, WEP security enabled, would appreciate your kind assistance.
1. Open routerlogin.net on your browser and make a note of your password/key code.
2. Click settings on your handset. Proceed into wifi settings.. Make sure wifi is turned on. It should now search and presumably find your connection with a lock symbol near the name. Click on the new found connection and it will ask you for your password/key .
3. Enter that and now it should connect. This is a one time procedure. Hence forth your handset will remember the password.
I hope this helps. Cheers.
Thanks for the suggestions tried both the above, unfortunately did not solve the problem, any other way to resolve this issue.
Could you elaborate more as to exactly when the problem is occuring ? Also have you connected any device through wifi earlier ? laptop for example ..
Also scan this thread to see if someone else had the same problem..
http://androidforums.com/samsung-galaxy-s/104468-samsung-galaxy-s-indian-thread.html
I have hp laptop connected to the wifi and its working fine, the problem is the mobile handset does not connect, what am I doing wrong for it to fail.
Is your router set to allow any wireless MAC address to connect?
If its only allowing MAC address which are entered into the router wireless setup then you will have to enter your phones MAC address into the router (this is assuming you have entered your wireless password correctly).
On my Linksys router its in the wireless setup options under 'Wireless MAC filter', look for something similar on yours.
