Need help to flash Jb Rom
Hello and welcome to the Boost Galaxy S2 section. You have the Galaxy S2 correct? The upgrade to the stock Jelly Bean is easy to do, there is a one click for it.
Check this thread link. It will link you to the repository where you can get the One click stock Jelly Bean install for our phone (choose either rooted on non rooted), and also the link for instructions.
http://androidforums.com/galaxy-s2-...root/780236-rooting-question.html#post6197580
Just click the link in my post. It takes you to my very post of the two links for what you need. The links are the blue colored text.
The exe files are a self contained installer. It is the ROM with its own Odin. run the exe to extract a folder with the one click ROM installer inside. Do note that the "restore" one formats the data partition, so copy all pics and stuff to an external SD card or your PC.
Look at that second link in the other thread post for instructions on how to do the one click.
