Help Need Help to restore widget (resolved)
monixtech
I was messing around and accidentally removed the widget for the most important people from the last extended screen. When I try to put the people widget back on the Extended Screen I get a pop up saying the "Your home screen is full, try removing an item to add another". The only thing showing on the extended screen are the icons for 4G, WiFi, Bluetooth and GPS connections at the top. How do I get that widget back on that extended screen as it was in how it came with the phone?
Thanks,
Mark
Most likely the widget requires multiple rows and columns. I'd recommend going to a blank homescreen and putting it there, then make room on your main home screen and then move it there.
yeah the recent people widget needs the entire screen so nothing else can be on there.
just as stated above, go to the blank screen, tap/hold , select widget then the people widget (or any widget you are looking for..this instruction works with anything) and BOOM. done. NEXT? :D
New to Sense 3 are more People widgets.
When you get to the People widget selection, scroll right to the last one. It's a row shorter and will fit into the space you describe.
That one leaves space for the other widgets you describe.
Nothing HTC distributes is locked away from user recovery.
