theRAYMOND
So I tried rooting my device through Odin and it said it passed, but when it rebooted it said, SuperSU was not working. And when I checked my root status via root checker, it said I did not have root. So I tried it again (rooting) and that's when it all started going bad. I factory restored it, but when it went to the set up screen, I couldn't get past the Date and Time screen because it said Google Services stopped or something. So I tried flashing again and now, it doesn't boot regularly. It only boots into CWM recovery. I tried putting a micro SD card in and flashing a ROM, but it wouldn't mount my SD. So I don't know what to do now.
it can access internal but not the external card. the problem is during the unroot process after the SU files were deleted i made the mistake of factory restoring the device form privacy settings instead of using CWM. now all my phone does is boot into CWM when i try to turn it on. i tried to install the zip files onto my external card so i could fix the problem but when i tried to access the zip files on the external card after putting it back into the phone i get a message in CWM that is telling me the external card cant mount.
tl:;dr When I try to boot Note 8.0 it automatically boots into CWM recovery and there's literally nothing on my device but CWM folder.
