Root need help unrooting then rerooting
UGAdroid
Member
SO here is my current phone status:
System version = 5.5.886 XT875
Baseband version = CDMA_N_03.1C.57R ltedc_u_05.15.01
Webtop version = WT-1.3.0-108_DBN-21
Kernel version = 2.6.35.7 -g68606e6 vwm736@il93lnxdroid43 #1
Build # = 5.5.1_84_DBN-55
I read somewhere on this forum that this is a combination of two different versions? I cant seem to find that post. I ran Pete's tool to unroot in order to try to re-root a different version. My phone is currently unrooted, but stuck on Liberty Rom, with Bionic Bootstrapper.
I am not able to re-root in any tool I try...using tehRoot, this is what I get:
Press any key to continue . . .
'adb' is not recognized as an internal or external command,
operable program or batch file.
+ Running zergRush exploit!
+ Waiting for phone.
+ Installing files...
+ Congratulations! Your Droid Bionic is now rooted.
+ Press ENTER to return to the main menu.
Even though the last line says im rooted, i am not.
Help please to get back to root!
Thanks!
and this is what it says when i run Petes root tool...
ERROR: adb could not be granted root access via local.prop method
Try again from the start, but if the problem continues, check your version
of Gingerbread -- hopefully you don't have a version where this exploit
was fixed.
So confused...
