need help updateing firmware
spyvy
Hey guys i have a Curtis proscan plt1044 tablet I need help tp update the firmware with a new factory one And i need to know how to install the new firmware ... Or if there is a better firmware for this tablet that will perform better than the new firmware specs are listed below ... Any help would be great on how to do the procedure of firmware instalation Thank you very much
Specs
10.1 inch screen
front camera
os/ Android 4.0.4
super 3d gpu
nand flash 4gb
expandable 32gb
processor boxchip A10
1 GB ddr3 ram
capacitive touch screen
display resolution 1024 x 600
hdmi , 1080p
two mini usb ports
mini sd/tf card slot
I believe this is a cheap imported device of unknown Chinese manufacture, which basically means there is very little or no information and support at all for software ROM upgrades etc. Doesn't appear to be any ROMs or other support at all on Curtis's website.
Curtis is a US importer of budget tech products, they also brand their imported products as RCA and Sylvania.
