Root need help updating clockwork mod 2xxx to 3xxx
Vowalla
Member
i don't know how to upadte it, i need 3xxx for cm7
does anybody know what to do with the img file, i'm lost here o.O
i don't know how to update it, i need 3xxx for cm7
go to market and download rom manager, that's the easiest way, also you can use any version to install cm7, but cwm 3.0.0.5 is best to use cause you can now download roms straight to you phone. once you install rom manager tap flash clockworkmod scroll down and choose huawei ascend and it will automatic download cwm and install it...:D
once you install and PAY FOR rommanager you can access the roms directly on your phone.
Ok. Thanks everyone.
I've been trying to go into clockwork recovery but it just doesn't work
i pressed the vol up + call button and power button and still doesn't work
I did like you said Token but still nothing, it only stays in the huawei logo screen
I wanna install cm7 already D=
First, you would shut down your phone and boot it by pressing the volume down, end, and power buttons. Then you would install CWM.
After install, take the battery out then put it back in then you press Vol up, call, and power buttons. This will get you into CWM so you can install CW7.
i justed seemed to like it better , i know its odd, so do i down load that and install it like the original?
yes...
im using the free version and i still can download the roms straight to the phone...Open rom manager tap download rom, tap icarusMods, tap cm7-ascend-05142011, tap download...
