so i have had my shift for a couple months and a couple weeks ago it started freezing first i would just lock screen and it would go black and not light up when i pressed the button again so then i proceeded to take out the battery and reset the phone.. and it worked for a couple days then it happened again.. i pulled out the battery and reset it.. this time it stopped loading at the 4g screen and didnt boot up fully... i began to press the lock screen button over and over... it finally booted up after a couple mins and then shortly after froze again... so i pulled out the battery and this time i held the power button and the volume down button which brought me to the hboot? menu? where i did a factory reset and it worked for a couple days then started happening again.. then i factory reset again and again and again...the screen goes blank 3-5 times now when i try to reset it to factory default and i have to take out the battery and put it back in and turn it on then it continues and so on... when i try to turn it on it stays on the htc screen ...(the first white screen),,, on occaision it will make it to the 4g screen(third screen ... following is the phone actually booting up) and a couple times it has made it to the booted up lock screen but when i slide down the bar it either freezes or the screen goes white and it says htc and then freezes shortly after..i have no clue what to do or if i shouldt be trying to reset it to factory as much... idk... anything will help and if you need any more info just ask.... THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!![/SIZE][/SIZE]
