Help Need help with 2.2!
Kachatz
I have the Motorola Droid with Verizon and was prompted to update to 2.2 today, so of course I did. Since then I have regretted it and need some help.
Here are the issues I have come across:
-Home Button no longer works, same with the search button.
-No flash player.
-Texts no longer ring when I receive them, unsure about phone calls yet.
This is just what I have noticed right away. I haven't explored too much else.
If I can fix the home button issue, I can live without the flash player( although its why I upgraded in the first place.)
I haven't seen the phone slow down, or lose battery life.
I have restarted, and still had the same issues.
help?
Have you tried a reset following the upgrade?
Shift + Ctrl + Del (on the hard keyboard).
Just got my update, yeah.
Can someone tell me how to change the security pattern to a number? I am not sure where this is located.
Lastly, each time I use google on the droid it never finds my location even if I just used google maps or GPS. Any Idea why this is and how I can get location to work so I can find nearby things?
