First of all I would like to mention that I have searched this forum for an answer, but didn't find one.
Here is my problem: I have a 3 week old Galaxy S2 and its only problem is that sometimes it's consuming battery like hell. I noticed there are 2 phases. First it consumes just a bit, something like 10% in 6-7 hours, which is very good, but other times, even while staying on idle, it drains like 15%-20% per hour. This usually occurs after I use it (play games, navigate on the internet) and it doesn't stop until the battery dies. It's not just one application that causes it. I always make sure that all the applications are shut down correctly and I have also tried battery saving applications, but none work. I suspect there might be a process/service that is draining my battery that much, but I couldn't find out which one.
I'm sure I'm not the only one with such problems.
Also, I'm in search of an application that blocks auto-starting applications that run in background.
