Help Need help with beautiful Widgets
MrOblige
Member
I downloaded beautiful Widgets however, whenever I go to the app drawer and select it instead of going to the setting I am asked if I want to go to playstore or aptoide. If I press back I get a black screen with the app's name on top. Any suggestions?
Uninstall, reinstall
Did you get it through the market?
(if you got it illegally it probably had a license check... BUY IT the legit way)
I got it from aptoide. All i did was uninstall aptoide then reinstalled it, update my repos, and the downloaded it gain. Works just fine now:D
