Need help with Google Android 2.2 HDMI TV Set-Top Box
vamozoty1
Hi, I just installed the Google Android 2.2 HDMI TV Set-Top Box. I entered my WAP password for wifi, but there is no were to enter my access password. Any suggestions?
Hello,
Welcome to Android Forum. I've tried to find a solution to your problem, but unfortunately... I couldn't seem to find any. I hope someone with a solution will eventually chime in to help. Best of luck.
Enjoy the forum. :)
Hello and welcome to Android Forums. I don't have a solution for your problem but I might suggest that you try asking your question here: Android Lounge - Android Forums You should have a better audience there and perhaps someone that can help you with your connection problem. Best of luck and thanks for joining AF.
