Help Need help with Hudl 2
Spadger44
Hi, can anyone help with my question?
I recently shot some video footage using my Fujifilm camera and downloaded it to my desktop computer. From there I copied it to my Hudl. The files are in .mov format (which I understand is an Apple/Mac format).
I have found a suitable player that works with this format,but my problem is that I want to attach the video files and send them via email, but even though the player finds the videos ok, I am unable to find the files to attach them. I have searched photos and gallery but they're not there.
Any suggestions?
Using a file manager, can you look for a downloads folder and see if they're in there?
Alternatively, would uploading to cloud storage (Dropbox or something similar), then downloading them on the Hudl be better than emailing them? You'd get to specify the download location that way.
