SamsungAdmire
Android Expert
OK, i was trying LGHome.apk from the optimus m ..(don't ask why..) and after rebooting, my Android Keyboard kept force closing and the launcher didnt show up, so i removed the Home.apk since the FC'ing was getting annoying,
Now that ive removed it it Android keyboard (latinime.apk) wasnt working, but FC'ing. I've redownloaded stock++ (Not reflash, redownloaded it) to pull the latinime.apk and put it on system . I did everything right, but dont know about the libs. Where is /lib/armeabi? I set the permissions correctly and stuff, i dont know why its Force closing.
Thanks.. If you can create a flashable zip to see if that helps, that would help even more.
